- Mon Oct 05, 2020 2:34 am
#93356
Anyone can help me please in regards oilway from feed pump to oil filter chamber. Just curious how to oil flowing from feed pump to oil filter chamber cause i didn’t found that oilway in timing cover and oil filter chamber. Refer to oilway schematic which drew oil flowing from feed pump to oil filter before goes to crank case.
There is small hole behind oil pump chamber (picture attached, in red circle) but it has stuck in oil chamber.
The problem was began from oil flow to rocker just flowing for minute without air bubble after motorcycle parked for few days and oil will flowing again after i stop a engine for few hours but it just flowing for 30 second without air bubble.
Thank you and really appreciate for your help.
