- Sat Feb 15, 2020 10:49 pm
#87834
Trying to figure out how to adjust this? Tappets set correctly and following the guidance in the manual (blue cover one), don’t get the instruction about setting valve clearance to 0.1mm on the exhaust valve and then adjusting it up with the decompressor cam. I can see how it works but can’t get it to do properly. There is a collar on the exhaust cam follower and I can see the‘cam’ is placed under the collar so when the collar is lifted it raises the exhaust pushrod and decompresses the engine. Do I need to adjust the cable so all the backlash in the collar is taken up to ensure maximum lift? Seems at present the cam is just lifting the backlash and not the pushrod? Sorry hope that all makes sense?
2006 Electra X and 2008 350T Bullet Watsonian Trails conversion
