- Fri May 18, 2018 11:54 am
#76856
Hi Jamesy ( how come you've got 2 listings the same ??? )............My guess is that it's an ATF ( Automatic transmission fluid )......but it could be any old thing.......Best bet is to drain and re-fill with an oil of your choosing........It's a small capacity so won't cost much, but at least you'll know what's in there...won't you ??..........Personally I use ATF in the front forks also as it copes very well with the high shearing forces that the damping valve imparts , but that's up to you..
