- Sun Apr 29, 2018 1:10 pm
#8381
One for Paul really.
Hi Mate
as you know I had no end of bother getting ASBO 26 to run properly.
So in the end I decided to put the Valve timing back to standard and hey presto its running.. Ive dropped the needle jet down to a 107 with needle in mid position.. Not saying its correct yet but its in the zone and rideable enough to allow carb tweaks and dynamic timing to be carried out..
The engine runs on Ok now instead of cutting out and the throttle is responsive..
Ill report back once Ive sorted the settings out and let you know what they are.
I will try retarding the inlet cam again once the initial set up is sorted.
REgards
Tom
Hi Mate
REgards
Tom
