By Presto
#74032
Why all these ‘snake oil’ remedies? CARB-CLEANER is the purpose-made product – cheap as chips – simple to use – readily available – every workshop should have a tin! Shame if you haven't! ;-)
By ric
#74033
Some of these snake oil remedies will actually be found inside a tin of Carb cleaner ;)
#74034
What type of oil do snakes use in the Winter ??--- Mono or Multi- ??.....I do use a carb cleaner but only to loosen up the crud before hitting it with those ultrasonic sound bubbles....
By Presto
#74035
Seems now we’re going from snake oil power-hammers to crack a peanut!
By papasmurf
#74036
I bought a Toyata Yaris VERY cheap (it had not turned a wheel for two years, but kept in a garage for two years until the dead owners estate was sorted.)
It had a few tick over issues it over revved on starting and stalled when hot.
Problems solved with £10s worth of mechanic in a tin spray through the air inlet whilst holding the butterfly open.
Not have a problem since.
By Revband
#74037
Carb cleaner, good stuff, not in everyone's shed?, Vinegar, coke, in most House's or cheap and handy from the local shop.
The thing with that varnish is, it can be very tenaceous. Sometimes it's just easier to replace the jet/filter than to clean it (especially with Enfield parts prices). I've seen me "boil in the bag" them in acetone in an ultrasonic before (So hot water in the ultrasonic then seal the parts in a bag containing your solvent) You place the bag into the water and run it. Easier, cheaper and safer than putting solvent in the ultrasonic.
Carb cleaner spray is often not man enough to shift that kind of varnish stuff. Often times not much is, even with ultrasonics and strong solvents. What WILL reliably shift it is MEK but it's increasingly hard to get hold of in any quantity.
By Valsp
#74041
MEK is also used for cleaning plastic fittings prior to welding with glue. It is available on Amazon UK
By Tomshayes
#74053
Well thanks for the suggestions but it turns out gunged up fuel lines / carb / filters isnt the problem after all..
i was expecting poor fuel flow when i drained the fuel tank but its fine so back to the drawing board!
Further investigations required!!
Tom
