- Fri Jul 21, 2017 5:48 pm
#7538
Hi
This concerns 250 Crusaders.
For a while I’ve been searching for a serviceable HG11 21/17 slider gear for a 4 speed gearbox without much success. However recently I have managed to acquire one from a fellow member of the REOC.
But on inspection there is a problem with the dogs on the side that mates with the dogs of the mainshaft low gear. Those dogs display significant wear and rounding of the corners. The dogs on the opposite side of the slider gear appear in good condition and have minimal wear.
In view of the difficulty in obtaining serviceable HG11’s I am having to contemplate repairing the dogs by getting them re-cut them and then possibly re-case hardening the whole gear. But I think quite a bit of material may have to removed in order to fix all of the damage on the dogs. I’m not sure if these gears are fully case hardened or not.
Has anybody else done this successfully, and can you point me at suitable engineering companies that would undertake such work?
Regards OB
Regards OB
2 x 250cc RE Continental GT
