- Wed Mar 01, 2017 6:29 am
#65981
There is a difference between the G and J/J2 gearboxes, but only in the casing. The G has a wider mounting top and bottom than the J so a J gearbox will not bolt in directly. However a G gearbox can be fitted to the J if the mounts are trimmed back on one side and then spaced across on the other. This is to correct the difference in the engine/gearbox centre line measurements owing to the wider 500 cases. Regards.
