- Thu Jul 07, 2016 10:14 am
#59807
Steve T - those look like the Halcyon but stretched and smoothed, nice. The Halcyon (type) do not dance around like the martian antenna Minda stock ones. If you have forced silicone into the bars then you do not have the welded-in nut for the bar end weights, which do work. Harleys probably have worse bar vibration than a RE, and they have all kinds of weird solutions, lead shot, ball bearings; look up "bar snake" which appears to be a lead-loaded plastic rod you force through the bars.
