- Tue Feb 24, 2015 11:15 am
#44628
[center]
Assuming your bike is per 95 diagram...
The tail light is connected to the two tiger's eye pilot lamps, the speedo and ammeter illumination and the pilot lamp in the headlamp shell (all depending on if these are fitted to yours or not.
one of the main lighting switch terminals has a pillar on it which connects it to the middle of the switch as per photo below. This is terminal No.6 and should have three wires connected, post probably to a spade terminal at the top. With the lighting switch on H, make sure you have power to this terminal, which comes from terminal No. 2 (brown wire).
The three wires are:-
Orange or brown in your case, to the tail lamp.
green to the tiger's eyes and headlamp pilot
orange to the ammeter and speedo illumination.
IF earthing the tail light works, but earthing the pilot lamps does not, then look at the connectors in the headlamp shell for bad connections:-
one 4-way with two green wires and two others possibly black, going to the pilot lamps
one 4-way with three orange wires. one from switch, the other two going to the speedo and ammeter to power illumination.
the headlamp
run out of the switch via the blue wire, to the dipper switch or 'cluster' switch, it then runs as two wires to the headlamp shell:-
(Hopefully) red which is the low or dipped beam supply
(hopefully) white which is the main beam. there will be a connector in the headlamp shell from the main beam wire, with a third wire that goes to the blue main beam tell tale in the speedo.
If that don't sort it out, go down the end of the road, turn right four times, that brings you back here, then ask again!
tabellarius de verbis ostensor gaudium
the headlamp
REOC 15084
Tabellarius de verbis. Ostensor gaudium
