- Wed Nov 26, 2014 9:50 pm
#41979
Oh, Scaly, I forgot to say: why not use the electric start? Especially when it cuts out at a road junction. It's MUCH safer than walking it to the side and kick starting.
And now for a bollocking!! Don't even THINK of swapping the EFI system for a carb! Carbs are crap compared to a good EFI system like ours. Anyway, you've no idea yet whether it's even the EFI that's causing the problem. It could be an ignition fault, dodgy battery leads, anything.
Intermittent cutting out like that is not a known failure mode of the ECU/EFI box, so don't start throwing expensive new parts at it hoping one of them will cure the fault!
I know you know this, really, but we all need reminders sometimes!
