- Sat Mar 15, 2014 10:37 am
#3382
Hi all, still playing around with jetting on my 2003 Sixty5. Have needle set at max rich setting already with 117.5 main, 25 pilot, but not sure which needle jet.
When riding on about 1/3 to 1/2 throttle, doesn`t seem to be pulling right, went out yesterday and when accelerating I reached over and put choke on. Bike "shot" forwards with a much healthier sound from exhaust.
The slide is a No.3, standard, but I have machined 1/2 millimeter from bottom to give a 2.5 slide, which improved pickup.
The bike has, as I bought it, had clean air gubbins removed and pod filter fitted, and the jets are also as bought.
I am going to try either a 120 0r 125 main jet, but would like to improve half throttle mixture by fitting a bigger needle jet.
OK, my question, (finally), is how do I remove the needle jet? our hosts instructions are a little vague, saying it can`t be removed from float chamber end, and to remove top and remove jet. Which way, up from bottom, or down from top? I guess it`s tapped out from bottom after removing main jet and washer, but don`t want to start tapping without knowing.
Ray.
Ray.
