- Wed Jan 30, 2013 6:33 pm
#1741
Wile returning from a afternoon ride my Enfield decided to stop!
I have a Electra EFI its on a 10 plate, what happened was I had just pulled in to my drive wile trying to find neutral the engine stopped and the lights switched off, so I switched the ignition off then back on again nothing.
I then proceeded to check the kill switch, it was correct so checked the ignition switch and it was fine but there was a bit of wet stuff in there could this be the problem, I mean there was slight condensation but that was it any advise would be appreciated.thank you
