- Thu Aug 30, 2012 5:31 pm
#16821
I have a 1953 Model G (hopefully I haven't troubled you with that one too much before...), and first of all I can just state these facts: >>> 1. The Model G engine is the one showed in the youtube clip, with iron head and barrel. >>> 2. This engine has only one alloy rocker cover with a simple cork gasket visible all around the head. >>> 3. The valve lifter has no connection to the head whatsoever, it just lifts the exhaust valve. -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. As Les H points out, smoke coming only from the head and not from the exhaust is not likely at all to come from inside the cylinder. So most probably there is an oil leak somewhere else. -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. The most likely places for oil to leak is >>> a) around the rocker cover, >>> b) around the pushrods where the head meets the cylinder, >>> c) where the oil feed connects to the head, or (this is a long shot) >>> d) through or along the valve guides. There really aren't any more places, I think. -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. a) to c) are all easily visible from outside. My G engine has a "type B leak", but that has never caused any smoke at all, just some oil down the cylinder obove the valve adjustment cover. a) might cause smoke but should be easy to locate. c) is just too simple to find One must be blind not to see it! d) can cause pressure inside the rocker cover that MAY press oil hot oil and gases out through b), but that should then be visible. Also, what is the probability that two heads has the same fault? -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. You say that "lots of oil pumping out of the rockers" when running with the tank and rocker covers off. Yes, of course! That is how the rockers are lubricated...... That oil should not produce smoke unless there is a leak somewhere. -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. >>> Are you REALLY shure that the rocker cover gasket is good and you can't see any oil leak there? >>> Are you also 100 % shure that the head is clean and dry in all nooks and crannies? There are a few hidden spaces between fins etc. on this iron head that are VERY difficult to clean out completely and may be full of oil or grease that causes smoke. >>> Are you 100 % shure that it is not the wrong type of paint and it can't stand the heat? It gets pretty hot around the exhaust..... -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. This is strange. From my experience from owning, rebuilding, riding and maintaining a Model G for 11 years I really can't figure out what might be the problem. Sorry! -.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-. PLEASE tell us when you have solved this! Good luck! Regards, Anders F. R.
