- Wed Aug 01, 2012 11:03 pm
#15457
Noel,
Well said, and I'm a Grunda fan, he tries hard. This bit of info now is for 5 speeds so people with 4 speeds please stop offering advice as it has no relevance to the 4 speed, completely different setup. As for the cable breaking in the box on the Electra it is usually as a result of the clamp the cable nipple fits into, it causes the cable to flex and a flexing cable WILL always break regardless of the thickness of the cable, just a thicker one takes longer to break. The cable clip has to be able to freely float. As I said in an earlier post it was a design fault, rectified on later models.
