- Sat Nov 26, 2016 4:20 pm
#6897
Hello, my iron barrel bullet 500, year 2006, 5 speed is loosing compression. Because of that it doesn't start. At the same there must be a crack in rocker oil feed pipe, because there is oil leaking (from the place where pipe splits to two pipes). Might be these two issues connected? Could compression also be lost through that pipe? I'm just learning mechanics, so pardon if it's really silly question.
p.s. that crack is fresh issue so luckily no damage done.
Thanks
Thanks
