- Tue Nov 01, 2016 5:27 pm
#6838
Hello, I bought myself a 2008 electra x a few months ago and I am slowly trying to get my head around a few things about the bike.
As it tends to kick back on starting and also pops and splutters when i throttle down I thought checking the ignition timing would be a good idea. After reading a few things on the forum and online it seems that the ignition timing can not be checked or really adjusted! Is this correct? From what I have read it looks like replacing the TCI unit or trying the timing adjustment keys from Hitchcocks are the only ways of improving the ignition timing? Is that correct? If using the timing keys is it a case of trial and error as I see 4 keys are sold with different degree adjustments?
Would I be right in thinking that the kick and spit backs could alternatively be a carburation problem? The guy I bought it from told me he had replaced the original silencer with a straight through one from India. Again from what i have read it looks like the carb jets should be changed if the silencer is changed. Can anyone tell me what size carb jets I need if a unrestricted silencer is used [do i need to check if the down pipe is also straight through}?
Last mystery [at the minute anyway] concerns the electra x manual or CD by Pete Snidal, one or two online comments I have read have been critical of these so any advice regarding what is the best workshop manual for this bike would be appreciated.
Thanks for any advice, I have a feeling in my water these mysteries are just the tip of the iceberg!
