Hello FROSTY-----------OK, here we are then-------- There were 2 types of filter fitted to the WD B40 ie}---- an "early" type made by VOKES which has a washable gauze element ( up to 1965 ), and the "later" type made by British Filters Ltd. which has a paper element ( 1965 to 1969 )............These two are NOT interchangeable !!.........However, the "early" Vokes and the Enfield Electra X elements are same diameter but differ slightly in length, the RE one being about 10mm longer...... Also the ELectra X type will need a thin mounting plate with a raised centre to act against the spring and seal the filter at the bottom ( otherwise the oil will just go straight through.. ( I'll phone our hosts tomorrow and see if that plate is available from stock)..............This will be a very useful conversion as the Vokes units are very scarce indeed.....
