By Phil Ashbrook
#3327
Getting my 612 crank order ready but unsure if I should get bigger jets , I'm building my 612 engine the slow way and the last bits need adding .
I'm gonna take the plunge on the race valve set(90052) and with all that extra space too rush by more should get in but... a thinner mix with fuel/air ?
32mm at the intake joint still , will it be lean or the same ?
By another Allan
#33753
I think I'd speak to Hitchcock's for some guidance. They must have more experience of the 612 than anyone else, and I'm sure that they'd be happy to advise you.
By devon john
#33766
i am in the same position getting parts together, but i want a soft torquey engine i will be going up to are hosts in a couple of weeks to get the 612 crank ,barrel and piston and associated parts. as you i have a 32mm amal carb and want to know jetting etc this is the main resin to visit the shop
john.
By Phil Ashbrook
#33773
I'm using a Amal concentric MK2 which is bigger and better than the MK1 , I had to saw off 1 petrol tank fixing lug and cut back the lug on the frame and it's still a tight fit with the cable , I think the jets for it are 240 main 25 pilot and nuber 3 slide , choke dont work so I cap the air filter for 1 kick to wet the plug of which I now have 2 .The rubber tube stopps heat transfer and the manifold could do with a left hand curve as per Fury head .
By Phil Ashbrook
#33796
I dont know why the choke does not work , I start the engine using a foam air filter cup and wet the plug with a induction kick through with a touch of throttle then a real kick start and the engine bursts into life , if I apply the choke at this point the engine cuts out , I have a leftie lever thats hard to get to but it will never wet the plug . I live in Australia so it's never really cold so really no need for choke , the carb is a Amal concentric MK2 which is a joy as the slide never rattles never jams and is heat proofed by the rubber induction tube , I have the extended mixture screw so I can tweek the mix with my fingers for cold day starting .
