By Scalyback
#2730
Tornado, my 1994 500 Military Bullet has
a smith's (chronometric?) speedo, with
no warning lights, there being a
Separate high beam and indicator lamps
In neat little holders, one each side of the
Speedo.
Tornado
I assumed they were Our hosts and fitted
some time ago, but closer inspection
Shows them to be a different patten.
I looked up late 93 - early 94 Bullets
And found two more the same!
Late 93 bullet
Assuming these are factory fitted, could
someone tell me what type bulbs they
are as I am in France until my return mid
October, and was thinking of fitting LED's.
Also, would Tornado be a home market
Bike, later imported to the UK, as there
seems to be no mention of a military 500
here until 2002 ?
Thanks for help, Simon
#28834
Hi Simon there is a slight problem fitting an LED to the indicator warning light because they use one bulb to do both side indicators. It can be done because I did it on a Cafe Racer I built last year but sorry I have forgotten how I ended up wiring it. I'll have a think about it
#28836
Simon, just thinking about it I probably didn't fit LED's to the single indicator light, I fitted an alloy top yoke and thinking about it has 2 holes in the yoke and I think I fitted individual lights for each side in these holes. I don't think there is any way of using a single LED
By Scalyback
#28837
Thanks Norm, with Thunderbolt, my EFI,
I just ordered replacement led bulbs.
They were straight swaps with the
speedo bulbs and also the pilot lights.
I now see them even in bright sunlight
especially if i did not cancel the indicator
correctly!
I don't know if the
same thing applies to older Bullets?
#28839
Hi Simon wish I knew how they can make the indicator light work with an LED. Maybe they fit a diode in each wire that goes to the indicator light. I think that would probably work
#29062
Yes Norm, blocking diodes would do it. You just need to get the diodes the right way round and the LED the right way round as well. Unlike normal bulbs they are polarity sensitive. You can shrink-sleeve them in to make them tidy. Cheap as chips on Ebay.
By Roeland
#29066
I fitted 2 LED's for the indicator warning system. A lot easier. Unfortunately I managed to drill the holes out of symmetry and now have to remove all - refill - and drill again.
Regards
Roeland
By Roeland
#29067
Regards
Roeland
