- Mon Jan 07, 2013 10:39 am
#21254
Hi Guys----------SIMON, I absolutely endorse 100% all that MADMIKE has said !! If it's in the filter already---and, as you say--- a "fair bit" in quantity, then something is obviously wrong...STOP & INVESTIGATE !!!! This is to do with "Engineering Hygiene" and recognising a potentially expensive/harmfull(mechanically speaking) in its' early stages...As P says, the 2 oil pumps are Yellow Metal as well, so what if the SUPPLY PUMP is on its' way out ?? SAYONARA any moving surfaces, that's what....As a time-served Mech. Engineer with 40 + years in the trade, I know what action I would be taking to protect a large, fiscal & time investment--- and hoping for the best doesn't come into the equation.....PS}--- if it helps any, your'e not alone... I bought a SECOND Bullet last Summer and rode it home (200 miles)...There was a fair bit of smoke on the over-run, mainly at traffic lights etc. so I'm thinking just a head swap --- I keep a good range of ready-to-use items in the workshop... Off comes the head and, whilst at this stage so does the barrel, and guess what ?? The small end has been previously repaired with a bronze bush ------ This is now LOOSE and the piston can turn through approx 15 degrees !! SO, it's now an engine out and new con-rod ( ie crank strip & re-build ) PLUS new piston..... Hey-ho !! (Bullet Whisperer--- will be in touch soon)
