- Mon Oct 12, 2020 11:33 am
#93500
If you fit a fuel pump you'll likely cause more problems than you already had. You'd need one that produces no more than about 1.5 to 2 psi then cuts off (such as an old type electric SU diaphragm pump). Most small modern pumps produce far more than this so that would require a regulator...and so on, more complication.stinkwheel wrote: ↑Sun Oct 11, 2020 11:48 amI'll admit I have even considered the logistics of fitting a fuel pump but decided I will live with the idiosyncracies of the thing for now and put the time and money I would have spent on that towards setting up a mikuni.
