- Thu Jun 02, 2016 11:52 am
#58675
If it was piston or rings you would have heard it and the engine would have died a lot quicker than, "like it ran out of fuel". This is not definitive. Get it home and pull the head. You probably do need to examine the piston but if it ain't bust don't fix it; a failed head gasket will have oil everywhere and give you "low compression" simply due to leaking.
If the top of the piston is ok and the bore is not scratched up then piston and rings are probably ok and no need to remove the cylinder. Do change engine oil and filters and examine the used oil for metal, sieve it if necessary.
You will likely have turned what oil remains in the engine into black soup, so you want to flush that away with fresh oil.
If you don't feel confident doing the job (not everyone does) there are places that don't demand you sell a kidney to do what is a straight forwards simple job of swapping a head gasket. You will need a decent socket set and a torque wrench. For the parts give Hitchcocks a phone call and ask what's needed to do the job, probably a kit. Best of luck.
