- Wed Feb 18, 2015 10:38 pm
#44492
Stef, can I ask why you haven't fitted sealed bearing in this box, makes it so much harder to keep oil in it. Is this an Indian or English box? English boxes don't have a gasket, no idea why, but Indian ones do. Put a wipe of sealer on the end cover (one with the bearing in it) make sure you have all the studs entered including the detent before you tighten it up. Put some grease on the selector bits and the clutch arm bearing point, outer cover does not need sealing
