- Tue Dec 26, 2017 4:11 pm
#73188
On my Electra-X I usually managed with just the 18mm (⅜"Whitworth) hex plug on the end cover undone, using a pair of long-nosed pliers to toggle the inner cable end into the slot on the inner mechanism on the gearbox, cable adjuster on the box screwed right in, then fit the other end to the handlebar clutch lever followed by final adjustments.
The gearbox sprocket nut is 50mm across the flats, I treated myself to a new ring spanner - pricey - though a box spanner might be cheaper.
