By Thack
#57497
Gaz262 writes: "So basically it stops the engine turning backwards if it kicks back then?"
No, it isn't for that purpose. It's a freewheel device. Think of it like you riding a bicycle. The electric starter (you) can drive the engine (back wheel) through the sprag (freewheel), but when the engine fires and picks up speed (the bike goes downhill) the starter motor isn't dragged along with it (your pedals aren't forced to whiz round at high speed) and at that point you can stop pedalling.
"I see the Indian chappie fitted the primary drive back in without the sprag? What difference would that makes to an electric start model?"
The starter motor wouldn't be able to turn the engine.
"I see our hosts offer an upgraded sprag but I thought that these newer EFI engines had an auto-decompressor for the electric-boot? Wouldn't that sort of reduce the risk of kick-back?"
Yes, definitely.
"I have a 2008 Electra EFI which seems to be running as sweet as a nut at the moment, should I be worried?"
No. Just use it. It may never break. If it does, nothing bad will happen - you'll just have to use the kickstart until you've fixed it.
