- Mon Nov 11, 2013 9:38 pm
#30144
Having owned an EFI for just under two years and 8,000km, what you describe is a sure case for an experienced EFI dealer to sort. In very cold weather I needed the enrichment device, but as soon as it was running, it could be released. For the information of those who do not know the efi, the enrichment lever cannot be left in the on potion as it has a strong spring return. (Unless there is a fault with the cable or actuator.) Belching black smoke on full throttle, sounds like some sort of jet or injector problem and the processor is failing to regulate the mixture, but you do not mention any warning light from the management system. Get it to your dealer quick. Best regards.
TrevorCH
TrevorCH
