- Sat Jan 26, 2013 7:37 pm
#21867
Just thought I'd wrap this up for prosterity. After routing the cable very carefully step by step I finally established that I couldn't run it through the yoke and have the slide hit the bottom of the carb with the much desired thump, it was a couple of mm off perhaps due to the cable sheath being a little long. Eventually I drilled into the split ferrel at the handbar end just a couple of mm so the cable end could sit further in and it worked a treat, the new throttle cable works with life affirming efficiency. It's possibly the case that the replacement offered by our hosts covers such an ambiguous range that some adjustment is needed, I was just unlucky mine was in the direction not aided by the adjustment screws. Many thanks for the advice and found over a week without the rattlebone quite a tough challenge.
