- Fri Oct 26, 2012 11:23 am
#18859
Best way to tension the rear chain I have found is to sit on the bike and if going touring with all your gear on the bike. My 06 Electra chain when correctly tensioned hangs slack when on the centre stand. I read somewhere the Indian chain market sales took off when the Electra came on the market. This was caused by the new rear shockers that were longer and put the rear spindle to swinging arm way out of alignment causing the chain to tighten far too much off the stand. Set it by the book on the centre stand and it will be far too tight when ridden. Best to have a friend to help you to do this. I am not sure if this happens on other models but my none Indian chain has only been ajusted slightly over the 4,000 miles since fitted. Hope this helps Bertie
