- Wed Dec 29, 2021 8:56 am
#99519
Gentlemen – I seek advice. I have the same speedometer waving issue on my 1996 535cc Bullet that many others have. I have sought the answer with new speedo, new drive and new cable to no avail.
On testing, both speedo’s are rock steady if connected to a drill.
But on the road, the needle wags some 30-40kph width all the time. BUT if I pull in the clutch and release the throttle, freewheeling down a hill, then the wag stops almost instantly – even on a bumpy road. In fact, during freewheeling, the speedo consistently overreads some 10% at whatever speed I am doing (tested between ~30-110kph) when compared to the GPS-set bicycle speedo on the handlebars so I am happy the speedo and drive work correctly. This tells me that it is not a mechanical fault causing the wag but some sort of induced magnetism in the casquette from the manual throttle position. So what is causing it and how can I insulate the speedo from the throttle? Has anyone else encountered this? I am sure I've seen a comment like this on a bulletin board, but which one and when. NB: everything else in the casquette is standard OEM stuff from the late 90’s. Maybe if I stuck a couple of magnets on the casquette I'd get some other response.
Cheers, ChrisD
Cheers, ChrisD
