- Sun Oct 31, 2021 3:36 pm
#98796
hi / i am rebuilding a 1991 500 bullet and have changed the left handlebar control to the later dip main / beam type
ive replaced the headlamp switch with the off/l/ high type and have run the red/ black wire to terminal 3 and the brown live feed to terminal 1
the 3 wires amber and green are on terminal 5 and not 100 percent if blue wire from handlebar switch goes in the last post position or in the brass connector top of the switch
the other thing that in throwing me is i have a spare brown wire coming out of the loom that is a permanent live which does not go to the ammeter or rectifier
can any body help please
regards def
regards def
