- Wed Apr 14, 2021 10:38 am
#96335
Just trying a mk1 on my bike using existing throttle cable.
350 2002 Bullet
With the monobloc fitted, the cable adjuster was virtually all the way out.
The concentric slide would only go down half way at most.
Adjusted the cable for maximum length and the slide goes much further, but not far enough.
Is there a longer cable for these; well, longer inner cable I should say?
If you see the picture, that throttle opening (engine side) is way too big I’m sure. I’m not even going to start as it’ll rev like a banshee.
I might be wrong, but any carbs I’ve fiddled with are virtually shut at tickover.
350 2002 Bullet
