- Sat Mar 13, 2021 12:17 pm
#95665
I’m doing a little work to Gupta and will be checking timing.
I’ve got the Hitchcock article and I have the Boyer red ignition box.
I’ve got a timing disk and although I’ve timed many bikes, I’ve never used a disk! Mostly Japanese and German bikes that I’ve statically timed and occasionally strobed; never had a bike without marks.
I’ve read the article and will mark as per. Just wondered two things. Anything to watch for? And out of interest, if I mark the stator at 32 degrees and TDC, I guess there’s no way of triggering it manually and watching for spark at plug? Well you could, but it wouldn’t help as you wouldn’t know exactly where it should spark statically; might not be exactly TDC.... but it could be.... in other words, is static at TDC?
Oh, is the nut normal, or a left hand thread? Thanks
