Deformed bodies are common if you overtighten the flange.
Maybe get a vernier on it and check the hole for ovality.
Or put blue on the new slide and see if it's only rubbing front and back. (or scribble on it with a felt tip if you have no blue).
probably worth checking the new slide for roundness while you're at it.
By windmill john
#94975
Thanks for that, back in the house now. No need for the blue, you can now see the scores on the new slide.
I guess if the body is deformed, there is no harm in me working on the slide to make it match the body; nothing lost.
By windmill john
#94980
Body didn’t appear deformed when I checked with vernier caliper.
I then proceeded to Solvol the slide.
All good now, but did notice if I grip the body a certain way before I finished the slide, it did affect the slip.
Now decided that Amal carbs are not an alloy, but pure lead... :roll:
