By jawa-enfield - Wed Nov 11, 2020 11:22 am
#93908
Here, i dismanteled it again, her is the wheel on a bench, clamped by the axle.
The brake plate can tilt a little towards every direction when installed (whithout central nut)
1 When you apply force by hand on the main brake lever, you will have to pull the lever, or it will not move, by pulling it, you de-centralize the whole thing.and that is exactly what you do NOT want. I cannot explain more logic in this language.
2-When you apply force by hand on the brake lever, you have to aplly some force, also to stabilize the wheel, This will result problably in tilting the brake plate over the axle one way or a other, you cannot see this.
One way you find this out, by applying froce to the brake lever with one hand, trying yet to stabalize the whole thing, and twisting down the nut. when ready, the brake plate and central nut has - again- play and is loos again, as result of having it tilted when twisting down.
so.. HOW can one single person, being alone centering the brake plate by plulling the brake lever, applying force on it, WHITHOUT decentralising it AND twisting down the nut???
