- Thu Oct 08, 2020 5:48 pm
#93426
To be completely truthful, Colin, I have no idea but I do know that everything else is set up correctly.
It could be either that the fuel level is too low so when I close the throttle and pull in the clutch there isn't sufficient fuel in the bowl to keep it alive, but by the time I've kicked it up again, the bowl has filled sufficiently to feed the idle circuit again. Or, it could be that the bowl is too full so that when I pull in the clutch it dies because its too rich, fuel sloshes up and throttles it with what's called a rich cut, and then, as everything is set up ok, it kicks straight back to life and idles again.
Like I've said, I have no idea but it is driving me nuts so I'm willing to try anything. I'm clearly no carburation expert so these are just my thoughts not in any way a proven theory.
Michael.
