- Wed Aug 26, 2020 2:56 pm
#92490
Hi to all on here, I am new to the forum, and fairly new to motorbikes generally - I have been learning as I go fixing up a 2001 350 Bullet, and having great fun (for the most part!). It was my dad's and sat rusting in a lock-up for 15 years odd. I have since had it all the way to central France (from Luton) and back so I know it will run, however I just fitting a new Amal Concentric 600 and am having trouble starting it.
I have very thoroughly set the timing 0.8mm BTDC but get severe kick-back and smoke from the intake filter, which I interpret as the timing being too advanced. The only time I have managed to get it started has been with the breaker plate fully retarded, which is a long way off from a centrally placed position when sparking at .8mm BTDC. Then only by keeping the throttle open from the twist grip, before screwing the throttle screw fully in, which then gave some erratic up and down before dying. I am confident the join to the engine head is tight but not overly tight.
I have noticed a spot of black oil seeping from between the carb barrel and its cap, just beneath the cable adjusters, which is a bit disconcerting! There was also plenty of oil on the piston head judging from the tip of the measuring gauge when finding TDC. Is this a clue possibly, but I can't see what?
Perhaps someone can suggest anything? I know starting can be a many headed monster and have gone through as many threads/starting routines as I can digest but still no joy. Trying to avoid taking it to a shop!
Many thanks in advance. Simon
