- Mon Jul 30, 2012 4:43 pm
#912
Many of you will recall recent posts where I was trying to track down a problem with poor idle and carb blowback, but had traced the start of the problem to the time I replaced the points on my 500 Classic. I re-did these points at the weekend and, well, I never knew that a few thousandths of an inch could make so much difference. I thought I had gapped them correctly the first time, but something was obviously wrong, so I took another look at the problem. My issue was trying to find out the highest point on the rather peculiarly shaped points cam. Once I had taken the plug out and (with the ignition on) sussed out where the points opened and closed, the solution became obvious. The thing is that the highest point on the cam is not actually half way between the opening and closing points (as I had imagined). It is possible to use the cam centre bolt as a reference point, and doing this you can actually find the point quite accurately. Once I had positioned the points heel correctly, I found that the gap was too narrow...adjusting it up to 15 thou (the proverbial "light sliding fit" on the feeler gauge), and all is well, in fact amazingly better! Torque and acceleration much improved, motor eager to pull at all revs, idle speed is back to what it should be, and, although I am still apprehensive, the "carb" problem seems to have gone. Just goes to show that you can get used to anything over a few hundred miles. As a bonus, the motor sounds much better, with a "rounder" exhaust note (don't know how else to describe it) - not louder, just fruitier! Many thanks to all who put me on the right path. I will monitor things over the next few miles, and see what happens as things settle in...
Cheers
TimG
Cheers
TimG
