I have measured the pip from the mounting screw hole centre's
I can't see how it can run for 40miles before stopping if it's a fuel problem ? If nothing is stopping the flow of fuel, I jumped on the broken gasket as that piece could have blocked the float bowl port now and again causing fuel starvation
Now the Boyer I fitted one to a GS750 lowrider we built for my then Mrs! First time out on the bike it broke down with a flat battery about 30 miles from home
Got bike home checked the wiring could find nothing wrong
But fitted a superdream regulater/rectifier
Next time out same thing
Got bike back contacted Boyer they said it's a very reliable unit but can you return it
They replaced the unit as faulty I have to admit great service
Fitted the new unit all was good for a few months, then the bike would just stop it might run for 20 seconds or 20 miles but would always start immediately after
Enough was enough she wanted a piranha (spelling) ignition system fitting I said go back to points she said "I listened to you when you removed the electric star and said get the Boyer"
Anyway she bought the Piranha electronic ignition unit I sold it and without telling her refitted points
She spent the next two years telling people how good the Piranha electronic ignition unit is
I don't know what happened to the bike as she took it with her when she went
Dai
