#90921
Still busy with the front brake, got the wheel back, now with round druk and again linings made on radius.
Adjusting is again the problem (give the cable more slack and brake comes less free?)
Yes i iknow how to adjust a DL brake, it is not rocket science..
But enfield seems different
It seems to brake better when the central niut is a little loose and the brake plate has a little play?
With normal bikes these parts have to be secured and tight..
#90938
I can't believe that this front brake is still not sorted
Nearly two years and still not working
Am I right in thinking you have tried different drums different shoes different cams?
It has to be a problem with the cable or lever
Not all those parts you have replaced can be faulty
I gave you the rundown on how I adjust a TLS front brake before
Adjusted the way I said before mine will squeel the front tyre
You say you know how to adjust a TLS brake can you tell us the method your using
#90946
Give the cable more slack the brake comes less free?
Can you put up a picture of the brake plate with the linkage fitted
It should look something like this
Not the best pic but the only one i have
