- Wed Feb 12, 2020 11:41 am
#87780
Never done this job before and was hoping for advice. I wish to take the magnito off as intact as I can.
The bike is a 1957 350 Redditch Bullet with a Lucaas SR1 mag fitted. I understand I have to take of the auto advance unit inside the timing chest by unscrewing so far and then apply a spanner to hold the auto advance unit while continuing to unscrew as the auto advance pushes itself off the magnito shaft. Is this unscrew anticlockwise?
I then undo the three magnito screws from inside the magnito cover to remove it intact. I don't wish to damage the auto advance unit for obvious reasons.
Does the magnito spin clockwise or anticlockwise as the repairer (will do a pretest before dismantling) has asked could I check. I realise there is normally an arrow indicating direction of spin but can't as yet spot it. Maybe will be obvious when removed from the bike.
Any comments appreciated as although had the bike 14 years never done this job. Also I presume will need to retime the bike even if I don't disturb anything else, This will be another challenge!!
Regards
Hugh
Regards
Hugh
