By MartinB
#873
My 2008 (2010 registered) Electra X has today refused to start .Our hosts Amal carb kit and other mods have been made over the last 2 years.It's only done 2750 careful miles as i only use it for pottering around our local country lanes.Since fitting our hosts Amal upgrade kit it's never started on the kick start.It's also been making strange noises on the electric starter.Although i got it running this morning and again tonight it cut out and refused to start again.I tried bumping it without success.When the starter buttton is pressed the motor appears to do something but the engine doesn't seem to turn over.I called Carole Nash recovery and a nice man from the AA turned up on a Pan European.He told me amomg many others he owns a Velocette Venom and had no trouble kicking it into life.I admit to 35 years ownership of mostly electric start Jap bikes so my kick starting technique leaves a lot to be desired.From the noise the starter makes when the button is pressed he said he thought it was the sprag clutch that would need stripping and inspecting.There now seems to be a considerable amount of extra compression on the kickstarter.Any words of wisdom please?If it is the sprag are there any uprated parts that can be fitted and what's the cost likely to be?
