- Wed May 29, 2019 8:03 pm
#83289
Has anyone any experience of jetting an Amal Mk2 2932 and a trials exhaust?
I have a 1993(?) 500cc RE Bullet and have fitted our hosts:
Performance cams 90023
Alloy barrel 200071
Piston 90204
Trials exhaust 91012 and baffle
Performance valves 90052 and gas flowed head.
Starts fine, usually with a little throttle, tick over is fine, but not perfect as to sometimes splutters and stalls, running on a some throttle it’s very rough and worse on full, pottering about on low throttle and the plug is very sooty. I’ve taken great care that my exhaust isn’t leaking at the head and the carb rubber manifold isn’t leaking.
Currently the set up is:
Needle 2A1 (second groove up)
Valve 3
Pilot 25
Needle jet 106
Main jet 240
Air 1 1/8 out
Plug NGK BR8ES
For starters I'm thinking of ordering a smaller main jet to see if there is an improvement? should I order anything else while I'm at it, just in case?
Alloy barrel 200071
Piston 90204
Valve 3
Pilot 25
Needle jet 106
Main jet 240
Air 1 1/8 out
Plug NGK BR8ES
