- Sun Apr 07, 2019 2:38 pm
#9215
Riding along on my old faithful 2007 350 bullet last weekend thinking "This is running really nicely, I was going to de-coke it after this run but maybe I'll leave it." Purring along at about 60mph on a sunny day when it cut out. No funny noises, just total silence. Ammeter flicking away merrily but like I was coasting.
Pulled into the side of the road to have a look at it. Nothing doing. Turning over on the kickstart but no compression. Checked the tappets and the exhaust one was tight. Backed it off all the way, still tight. Hmmm. Ok, I'll take a look at the sparkplug. Ah, the end is missing and hammered like the end of a fencepost. Best call recovery.
Just whipped the head off this afternoon. I don't think this is a very good sign!
Now this bike has done a LOT of miles. I'd estimate between 70 and 80k and this is the first time it's left me stuck at the side of the road for anything other than a puncture. Although as is usual with these things, it's a bit like triggers broom. So that's one of our hosts tuned heads with the competition valves. the bore looks fine. The remainder of the piston that isn't full of valve is intact and still attached to the conrod. No detectable vertical play on the conrod. Bore looks fine, no scoring. Rocker gear is all fine, pushrods are straight, plenty of oil about in the top end. I think this must be a primary valve failure. I think the end just came off and drama ensued.
I'm going to have to split it because there's a fair bit of piston unaccounted-for so I'll replace the mains and I had been toying with the idea of a forged piston for it. The big question is, what about the crank? It's got a lot of miles on BUT it also seems fine. I've already spent a fortune on my 612 bullet so I'd rather not be throwing a new crank/big end at it unecessarily. Am I correct in my understanding that a floating bush is generally either perfectly ok or has failed, there's not much middle ground in that respect?
I'm hoping the head can be rescued. There's a few dings in it but if I tidy it up with a burr tool so there are no sharp edges/deep pockets, it should be ok?
On the plus side, that was going to be my last ride out before a major refit as a road trial machine so most of it was coming apart anyway. I hadn't intended to take the engine out though. Mind you, in some ways, tinkering with the chassis is much easier without the engine because I can get the frame in my heavy duty bicycle stand.
