- Wed Apr 03, 2019 9:30 pm
#82080
Cov Lad,
no, I don't mean tapered. Were you thinking of counterSUNK? Have a close look at the second picture, you see where the valve body sits IN the top of the head a bit? To do the modification as I did you have to drill right through the combustion chamber with a 1/2" drill, then you have to drill out the same hole PART WAY with a bigger drill.
The thickness of the casting at that point means that once you have drilled and tapped the hole for the valve body, you can screw the thing in but it it is recessed into the head somewhat. Whilst it is probably OK to use like that it does still mean that you have increased the combustion chamber volume slightly, causing what is an admittedly minor drop in compression.
To get the head of the valve actually to sit flush with the combustion chamber surface I then had to partly re-drill the hole from the top side of the head with a larger bit (I think it was 22mm) to remove JUST ENOUGH of the newly-threaded metal so that the remaining amount of thread matched the length of the threaded portion of the valve body, including the tip of the valve head. Think short-reach 14mm spark plug. This process also left a nice seat for the valve body to sit on/in. Do NOT drill down too far with the bigger drill or the valve body will protrude into the combustion chamber. Also you will not be left with enough thread to hold the valve body securely, which leaves you with a scrap head.
I have a couple more heads to so, so I will try and remember to take some work in progress pictures.
