- Wed Mar 13, 2019 7:39 pm
#81769
I have a 350 Bullet with a Mk1 Concentric Amal. I would suggest that you do NOT apply any choke, that you tickle the carb till petrol appears, then, as you say ease over compression with the decompressor open and then kick.
You may have other problems with jets etc. but this is the best way to start it. At various times in its history my bike has been an absolutely cussid starter and as now, first kick almost every time.
The carb in question is one of the Premier ones and I was lucky enough to have the mechanic at Sammy Miller's motorcycle museum, which is local to me, set up carb, timing and tappets. That guy can just scare bikes into starting!
