- Sun Feb 03, 2019 3:03 pm
#9052
I have had to reduce the length of the clutch pushrod when I replaced the old 4 speed box with a 5 speeder on my 612.
Possibly because of the Newby clutch the standard pushrod is too long, and for the Nth time now I have had to remove the pushrod to reduce it's length, currently I run just out of cable adjustment, and since the adjuster in the clutch pressure plate is backed right in the only solution is to take a little more off the pushrod.
Found an easy way to remove the pushrod from the clutch side - a small cylindrical magnet on the end of a steel rod pushed in from the clutch side, only problem was that I managed to move the clutch arm out too far on the gearbox side, so much in fact that I heard a familiar "tick tick" as one or more of the balls from the clutch mechanism fell out of the housing.
Drain the geardox oil again and take the cover off again.
Damn it - hopefully make the pushrod the right legth this time !!!
Previous bikes - far too many !!
