- Mon Jan 07, 2019 11:18 pm
#80843
Adrian - It certainly looks like you are on to something with the Minda switch ! I was not familiar with the internal connections of this, but it's a good thing you are ! (And as I have considered using one if I ever decide to fit indicators - thanks.........)
Re the wiring diagrams supplied by Davedup and Marko, I would question the wisdom of recommending them to Zelda for him to follow -
both would need modification, both have original Lucas 31491A lighting switches and Marko's has magneto ignition, not coil (or the
Lucas 34093B ign. switch. Furthermore, both have original colour codes to the wiring, rather than a length of shonky 7-core trailer cable and both are wired POSITIVE EARTH - something apparently overlooked ............
I suggest that if Zelda needs a wiring diagram to follow, he'd be much better off doing so with a 1646 wiring harness with all the correct colours that he or any subsequent owner (or AA/RAC man, etc.in the case of a breakdown) could relate to with ease and the lessened risk of a wrong connection........
Zelda has not stated his reason for the polarity change to negative earth, but I suspect that it was purely for the reason that it was the way it was in the original diagram.....
