- Sun Dec 16, 2018 9:22 pm
#80657
Measured things up - I/D of the O ring fitted in the case is approx 18mm shaft O/D is 19mm so the seal has to compress 0.5mm radially.
Biggest problem (partly my fault) was that the O rings for the kickstart shaft were dry, as was the gearbox lever oil seal.
I say partly my fault because I had the cover off once to change one of the clutch pushrods and should have lubricated the O rings and oil seal when I had it apart, although the assumption was that they would have been lubricated when put together originally.
Anyway I lubed the kickstart O rings and shaft and temporarilly re fitted the cover and I found that the kickstart lever would return under it's own spring pressure with a little help from me, so I guess that once I have kicked the bike up a few times all will be well.
Previous bikes - far too many !!
