- Mon Dec 17, 2018 12:54 pm
#80671
Might be easier to remove the gearbox first. Again, makes things lighter. You can usually wind the studs out with a couple of nuts locked onto them. Although if you leave it attached, the kickstart makes a good handle/lifting point to get hold of on that side.
Standing astride over the frame keeps you lifting from your centre rather than over to one side and wrenching your back further than necessary but as above, don't sit on it because the frame springs apart. (I used camlock straps to pull it back into alignment when refitting the last engine I did, this helped greatly). Having a box next to the bike to put the engine on once it's out is also a good plan, then you are just lifting it across rather than putting it down again.
Remember the stands and front footpegs are attached to the engine plates. I lift mine up onto axle stands under each side of the swingarm then chock the wheel so it can't roll off them. Make a note/take a picture of which spacer tubes go where before undoing everything
I also found podgering the engine bolts out first with a slightly narrower bit of bar that is left in place until you are ready to slide them out by hand made the job easier. Similar thing for refitting, getting it all roughly aligned with the narrower bar in holding the engine in place means you can bully/wiggle it into a proper alignment for fitting the engine bolts without having to support the weight of the engine.
Strategic use of an old car scissor jack under the engine also helps to take the load off the engine mounting bolts to facilitate their removal/fitting.
