By Andy C
#8978
Fitted the 5 speeder, just need to fill her up with oil.
Looks like Fuchs BOA 80W-90 is the stuff, question is how much, and do you fill it by removing the 18mm plug that gives access to the clutch cable.
I cannot se a level plug so I assume there is not one.
Any all comments appreciated.
Cheers.
By Frank
#80553
The level plug is one of the cover screws, about the 7 O'Clock position. Should have a washer on it to identify. Fill it through the 18mm filler hole until it comes out the screw hole.
By Andy C
#80558
Thanks Frank - I wondered why one of the screws had a copper washer under the head.
About 500 Ml to fill ?
